Folder Capture
This task can be found in the Plug-in Bar, under the Input tasks group.
Folder Capture input tasks retrieve files corresponding to a specified file mask, from a specified folder.
Folder Capture retrieves all files corresponding to the specified mask. These files may be of any format, even formats that are not readable by OL Connect Workflow.
Note: As with any task that can refer to network resources, it is important to understand the considerations involved with paths and permissions of these resources. Please refer to the Network considerations page.
Caution: If you create a Folder Capture input task that takes any file it finds in the root folder of one of your hard disks, then OL Connect Workflow will try to remove all the files located in that folder, including all the system and hidden files. So when using a Folder Capture, be aware of where you are capturing.
Each file capture by the input is sent down through the process, one at a time. When the file is finished, the process goes back to the input which feeds another file down, as long as there are files in the queue. Once all the files are gone, the task polls the input folder again to see if new files are present and, if so, the process continues with these files. Otherwise, the process ends.
The output to this task is a series of individual files, one after the other. These files are not modified in any way from when they are captured from the source folder.
- Folder list: Enter the full path of the folder from which the input files are to be taken.
 - Masks: Enter a single or multiple file names or use file name masks. See Masks.
- Treat as regular expressions: When ticked, the contents of the Mask field are deemed to be a regular expression . You can specify multiple masks based on regular expressions, separating the regular expressions by a semicolon.
The checkbox is not ticked by default. Please refer to Regular Expressions for more information.
Note: No Variable Data can be used inside this field if the Treat as regular expressions option is ticked. The percent sign, the curly brackets and the period are all key elements of the RegEx syntax, therefore they cannot be mixed and matched with Workflow variable data syntax (e.g. %1, ${global.myvar}, etc.). Also, there is no validation of the RegEx being specified.
Sort files by: Select a given sorting method to prompt OL Connect Workflow to sort the files in the source folder before taking them (and thus to take them in a specific order). Select None to let OL Connect Workflow take the files without sorting them first.
Note: Sorting can slow down the process, especially if there are many files to sort. The plugin needs a list of all files in the current folder to check the properties of each file before it can sort the files.
 - Sort order: If you selected a sorting method in the Sort files by box, select the order in which you want the files to be sorted.
 - Use archive attribute: Select to turn on the archive attribute of the data files found in the source folder and to leave them in their original location (i.e. to take copies of the source files). Note that OL Connect Workflow never takes source files that have their archive attribute turned on (so the source files will not be taken again and again). When this option is turned off, OL Connect Workflow removes data files from the source location.
 - Capture files in subfolders: Select to capture files from child folders of the source folder as well.
 - Sort directories first: If you selected a sorting method in the Sort files by box, and if you want the folders present in the source folder to be sorted first, select this option. When this option is selected, the chosen Sort order is applied to each separate folder, not across folders. The subfolders themselves are always processed in alphabetical order, regardless of the sort order.
 - Include hidden files: Select if you want any hidden folders or files present in the source folder to be taken as well.
 - Include empty files: Select if you want any empty folders or files present in the source folder to be taken as well.
"Other" Tab
- Job Information group
 - Backup input files: Check this to save a copy of each data file that is captured by your input. These files are saved in the OL Connect  Workflow Tools working folders under the "Backup" folder.
Job Information definitions
- %1 - Source File Name. Contains the file name (including the path and extension) of the file name that is captured.
 - %2 - Folder: Contains the folder from which the data was captured.
