Folder Listing
This task can be found in the Plug-in Bar, under the Input tasks group.
Folder Listing input tasks list the files present in a selected folder and give you the option to use filename masks, to sort files by name or date, and to list the files present in the selected folder’s subfolders. The lists it generates are in XML format.
Folder Listing captures nothing, however it does read the input folders (and, if selected, subfolders) and gathers information about each file in that folder.
Folder Listing loops through the files and, for each file, generates an XML node with information about the file.
The output is an XML file containing information about each file. If the Sub-directories option was checked, the structure of the XML also contains the folder structure as it is present on the drive.
Here is a sample of the XML that is generated:
<?xml version="1.0" encoding="windows-1252"?>
<files count="3" filemask="*.*">
    <folder>C:\Samples\<file>
            <filename>invoice.pdf</filename>
            <path>C:\Samples\</path>
            <time>2012/06/01 16:14:40</time>
            <size>81452</size>
        </file>
        <file>
            <filename>test1.pdf</filename>
            <time>2013/01/17 09:13:50</time>
            <size>20197</size>
        </file>
    </folder>
    <folder>C:\Samples\manuals\<file>
            <filename>usermanual.pdf</filename>
            <path>C:\Samples\manuals\</path>
            <time>1999/10/06 09:52:04</time>
            <size>644037</size>
        </file>
    </folder>
</files>
                                                Note: The <time> tag is independent of the OS locale, language or settings. The format is always YYYY/MM/DD 23:59:59.
- Input folder: Enter the path of the folder that contains the files you want listed.
 - Sorted by: Select either Name or Modified date, depending on how you want the list top be sorted.
 - File mask: Edit the default file name mask (*.*) if you want only some of the files present in the folder to appear in the list. See Masks.
 - List files in sub-directories also: Select this option if you want the task to list any files present in subfolders of the selected input folder.
"Other" Tab
- Job Information group
 - Backup input files: Check this to save a copy of each data file that is captured by your input. These files are saved in the OL Connect  Workflow Tools working folders under the "Backup" folder.
Job Information definitions
- %1- Folder: Contains the full path of the base folder from which the files are listed.
