Load External File
This task can be found in the Plug-in Bar, under the Action tasks group.
Load External File action tasks are used to replace the current job file by the designated text file. Loading an external file does not delete the original file or modify it in any way.
This task is put into effect in the following example process:
The current data file in the process will be discarded.
The external file specified in the task's properties is loaded and replaces the current data file.
The loaded file is output. Metadata is not modified in any way, neither are Job Info variables.
- External file: The path to the file you want the job file to be replaced with. You may browse to the file using the browse button on the right of the field.
