Download EML Messages
This task can be found in the Plug-in Bar, under the OL Connect tasks group.
The Download EML Messages task downloads one EML file from the Connect File Store. Saving EML messages in the File Store is an option in the Render Email Content task. EML files can be stored in an ERP/ECM system for archiving purposes.
Use the Metadata Sequencer plugin, followed by the Download EML Messages plugin and the Send to Folder plugin, to download multiple EML files and save them to disk.
As an alternative to the Download EML Messages task you could use the File Store - Download File task to download an EML file from the File Store. In that case you need the folder ID and EML file name found in the output of the Render Email Content task. This information can be retrieved from the Metadata using the following data selection methods:GetMeta(_vger_prop_folder[0], 10, Job.Group[0].Document[0])GetMeta(_vger_prop_eml[0], 10, Job.Group[0].Document[0]).
The Mailjet and SendGrid plugins offer the possibility to add extra attachments to a rendered email message via Workflow. Note that any such attachments will not be part of the EML file produced by the Render Email Content task.
Note: With OL Connect Workflow version 2020.1, using the Download EML Messages task requires the version 2020.1 Mailjet and SendGrid plugins . They are available for download on the Resource Center (https://olresourcecenter.uplandsoftware.com).
Tip: Double-click an .eml to open it in your email client.
This task must receive either Metadata or JSON Job Data containing information regarding a pre-rendered email message that has been saved in EML format in the File Store.
Storing EML messages in the File Store is an option in Render Email Content task. That task outputs information about the email messages that it pre-rendered either in the current Metadata or in the form of a JSON structure.
The Download EML Messages task expects UTF-8 encoded JSON job data files.
Note: Make sure that other components in the Workflow configuration working on the job data handle UTF-8 encoded files correctly.
The plugin communicates with the OL Connect Server to retrieve the EML file that was stored in the OL Connect File Store by the Render Email Content.
The task outputs the EML file as the Job File. The Metadata are unchanged.
Properties
Data Source (see Input):
Metadata: Metadata containing information about an email message. The Render Email Content task can output information about the email message(s) that it pre-rendered in the current Metadata. Use the Metadata Sequencer plugin to loop over the items in the Metadata and feed them to the Download EML Messages plugin.
JSON: A JSON object representing an email message. For an example of such an object, see the Render Email Content task. That task can output a JSON object (or an array of JSON objects) containing information about email messages.
Note: Information about the OL Connect Server (host, user name etc.) is taken from the Workflow Preferences (see OL Connect preferences).
Advanced Properties
