Job Statistics
This task can be found in the Plug-in Bar, under the OL Connect tasks group.
The Job Statistics task retrieve statistics for print jobs created through OL Connect Server. The data returned includes the number of documents, sheets, and pages used, as well as the media types applied. This feature is valuable for accounting purposes and helps you track costs for better budget management in a printing environment.
The output is a file in either JSON or XML format.
This plugin doesn't require any specific job file. The task takes a single Job Set ID, either from a task property, which can contain a variable, or from the Metadata.
Tasks that can output a Job Set ID to the Metadata are the Create Job, Retrieve Items, and All In One tasks.
For each document in the Job Set ID, the task extracts all of the relevant job details.
The task outputs the report either in JSON or XML format.
Job Set group: All the information regarding the Job Set.
Job Set ID: Enter a single Job Set ID. Or, right-click the field to open the contextual menu that allows you to select variables, data and lookup functions (see Data selections).
Use Metadata: Check this option to use the Job Set ID in Metadata that is the output of the All In One, Create Job, or Retrieve Items task.
Note: Metadata is only retained if this box is selected. When the Job Set ID comes from the metadata, it is likely that the metadata was created by the OL Connect plugin and can be reused later.
Scope: Enter the scope of the job statistics to gather. The selections are:
Documents: returns only a list of documents contained in the Job Set.
Documents and Sets: returns a list of document sets contained in the Job Set.
Document Sets: returns a list of document sets (including all of the documents) contained in the Job Set.
Output: Select the desired type of output file.
JSON: Outputs the job statistics report in a JSON file.
XML: Outputs the job statistics report in an XML formatted text file.
OL Connect Proxy Tab
This tab is common to most OL Connect tasks and defines where to process the jobs sent through these tasks. When these fields are empty, they use the defaults set in the OL Connect preferences.
