PDF to Bitmap
This task can be found in the Plug-in Bar, under the OL Connect tasks group.
The PDF to Bitmap plugin converts PDF pages to bitmaps.
The job file. This must be a PDF file.
The PDF to Bitmap plugin converts PDF pages to bitmaps, optionally scaling them.
Invalid pages or ranges generate an error; in this case, no bitmap is produced.
If the specified output folder doesn't exist, it will be created. If the folder cannot be created, an "Error creating directory" message is logged.
If the plugin can't connect to the OL Connect Server it will return an error message.
Note: As of OL Connect version 2020.2 the PDF to Bitmap plugin requires the OL Connect Server to produce output.
This could cause problems when running older configurations. To cure such issues, set the OL Connect Server connection settings within Workflow (see OL Connect preferences).
This task outputs the PDF file it received with no modification.
Properties
The General tab has the following options:
- Output format: The output format can be either PNG or JPG.
 - Resolution: Specify the resolution of the bitmaps (pixels per inch). The minimum is 12, the maximum is 1200. For example, with the minimum of 12, a PDF page that is 8,5 inch wide is converted into a bitmap of 102 pixels wide, which could be used as a thumbnail on a web page.
Page range: An asterisk (*) means: convert all pages. It can be replaced with a combination of the following, comma-separated values:
a single page number
a range of pages: n1-[n2]. If n2 is not specified, the range extends to the end of the file. Any value specified after the next comma is ignored.
Example: 1, 7-10, 13, 15- means the task will convert pages 1, 7, 8, 9, 10, 13, and 15 until the end of the file.
 - Output folder and file name: Specify where the bitmaps are saved; %t%O means: save the bitmaps to the current temporary folder, using the PDF's original file name. If no extension is specified, the selected output format is used to add the extension automatically. When multiple pages are saved, the index of each page is appended to the output file name (e.g. mybitmap1.jpg, mybitmap2,jpg, etc.).
OL Connect Proxy Tab
This tab is common to most OL Connect tasks and defines where to process the jobs sent through these tasks. When these fields are empty, they use the defaults set in the OL Connect preferences.
