Set Properties
This task can be found in the Plug-in Bar, under the OL Connect tasks group.
The Set Properties Action task defines properties for entities saved in the OL Connect Database (Records, Content, and Jobs). These properties are applied to the entities and can then be used to retrieve them using the Retrieve Items task.
The task must receive Metadata that contains appropriate entities, generally from the Execute Data Mapping, Create Print Content, Create Web Content or the Create Job tasks.
The task sets the chosen properties to all entities present in the Metadata. These properties are added to the entities on the OL Connect Server. Note that the properties are calculated only once, and are applied identically to all entities. If each entity should have different properties (such as record-level properties), the Metadata should be split using the Metadata Sequencer task first.
The task outputs Metadata that is identical to the input Metadata. Only the entries on the OL Connect Server side change.
- Entity: Use the drop-down to select the entity type of which to set the properties. This task does not auto-detect entities, and so the appropriate selection must be made: Record, Record Set, Content Item, Content Set, Job
 - Properties: Add all the properties to be added
- Name: The name of the property.
 - Value: The value to apply to the property.
 - Add entry: Click to add another line to the Properties list.
 - Remove entry: Click to delete the currently selected line in the Properties list.
 - Move entry up: Click to move the currently selected line up in the Properties list.
 - Move entry down: Click to move the currently selected line down in the Properties list.
OL Connect Proxy Tab
This tab is common to most OL Connect tasks and defines where to process the jobs sent through these tasks. When these fields are empty, they use the defaults set in the OL Connect preferences.
