Outputs SOAP Client
Note: This plug-in has been moved to the Legacy group. It is recommended to use the SOAP Client Plug-in Action/Output plugin and Input SOAP Input plugin instead.
Outputs SOAP Client tasks can be used as Input, Output and Action tasks, although their basic function is to generate output.
To configure a given Outputs SOAP Client task in the OL Connect Workflow Configuration program, you must first get its WSDL file (note that you cannot download the WSDL file over an HTTPS connection, so you should use an HTTP connection to get the file and then switch back to a secure connection).
If firewalls control communication between the Outputs SOAP Client and the Web servers, they must be configured so as not to block client-server communication.
In the case of "string" type data, Outputs SOAP Client tasks normalize all line endings to a single line feed character.
Timeout
By default the Outputs SOAP Client plugin waits 100 seconds before returning an error if it doesn't get a response. To change the time the plugin should wait, a Timeout registry key can be set in:
HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Objectif Lune\PlanetSuite\PlanetWatch\TimeoutVal (DWORD)
The value can be set to anything, in seconds. To wait indefinitely for a response, -1 can be used. However, this could cause the process to hang if the SOAP server never responds nor closes the connection.
Workflow's WSDL file
When acting as a SOAP server, Workflow must be able to return the server's WSDL file upon request. The actual links for accessing the WSDL file are:
With the HTTP Server:
http://[IP_ADDRESS]:[PORT]/wsdl/ISoapAct
With the NodeJS Server:
http://[IP_ADDRESS]:[PORT]/soap/ISoapAct?wsdl
Tip: This location is logged by the NodeJS server whenever the service starts.
Note: SOAP communication is non-trivial and requires a certain understanding of XML and the SOAP protocol. Using the SOAP tasks pre-supposes this knowledge and this documentation does not attempt to provide it.
For more information about SOAP workflows, see SOAP workflows.
- WSDL address: Enter the URL address of the WSDL file, or choose a previously selected address from the drop-down list.
 - Get: Click to get the WSDL file from the SOAP server and populate the Service box below.
 - Service: Choose an available Web service from this drop-down list to populate the Method box below. You may also enter the service name directly if the WSDL file cannot be found.
 - Method: Choose an available method from this drop-down list. This populates the Namespace box below. You may also enter the method name directly.
 - Namespace: You may choose an available namespace to prevent ambiguity between identically named elements or attributes. You may also enter a namespace directly.
 - Resolve: Click to apply the options you chose above and to display the arguments of the chosen method in the Arguments box below.
 - As script: Click to apply the options you chose above and to display information on the chosen Web service in JavaScript format in a script viewer. You should use this option if the Web service is too complex to be interpreted correctly by the Outputs SOAP Client plugin.
 - Name: Displays the name of the arguments associated with the selected method. Note that you may also manually enter new arguments, change or delete existing ones, as well as change their order if needed.
 - Type: Displays the argument type.
 - Value: Lets you enter fixed or variable values. To exchange variable information between the Web service and OL Connect Workflow, you must use job information variables %1 to %9 or variable %c (which contains the entire job file). Note that return values (arguments which are used to return information to the Outputs SOAP Client) are displayed in bold font.
 - Namespace: Displays the namespace of the arguments associated with the selected method.
 - Use returned raw SOAP packet as new data file: Check to use the complete SOAP packet (including the passed parameters) instead of the parameters only. This option overrides any return value set to %c in the Arguments box. You should use this option when the Outputs SOAP Client plugin is not able to fully support the syntax of the response.
Advanced Tab
- Domain: Enter the domain for the authentication on the SOAP server. The Domain is optional even when authentication is used.
 - Username: Enter the user name for the authentication, if required.
 - Password: Enter the password for the above user name.
 - Allow invalid security certificate: Check to ignore SSL certificates that are invalid.
