Metadata to PDI
This task can be found in the Plug-in Bar, under the Metadata tasks group.
The Metadata to PDI task takes the active metadata and generates a PDI using the information in that metadata. It is generally used in conjunction with a PDF data file and is used to generate the PDI file which is used by OL Connect Search when building, refreshing or rebuilding its database.
For more information about Metadata see Metadata.
This task can use any data file, as long as it is accompanied by metadata. This metadata may have been directly generated or could be extracted from a PDF using the Embed and Extract Workflow Metadata task.
The metadata is read and PDF indexes are located. These indexes are defined in the PlanetPress Design document as data selections, in which the Archive / Email / Fax properties define the data as an index with a name.
When all the indexes are collected, a PDI file is generated with those indexes.
The output is the same as the input, no modification is done to either the data file or the metadata. However, a PDI file is generated and saved in the location specified in the task.
  • Archive Folder: Specifies where the PDI file should be saved. This should be the same location as the PDF file that the PDI refers to.
  • Filename: The file name for the PDI. This name should correspond exactly with the name of the PDF that the PDI file refers to.
  • Index Group:
    • PDI: Only generate a PDI file.
    • PDI and XML: Generate both the PDI and an XML equivalent (not used by OL Connect Search).
