Create PDF/VT
This task can be found in the Plug-in Bar, under the OL Connect tasks group.
The Create PDF/VT, similar to the Create PDF task, creates PDF/VT files from a PlanetPress Suite Document (created with PlanetPress Design). This PDF/VT is compatible with the Create Print Content task directly without the use of a OL Connect Template (PDF/VT mode).
Any data file supported by the selected PlanetPress Document.
Note: Neither OL Connect or OL Connect Workflow contain any inbuilt anti-virus functionality.
We recommend following security best-practices when uploading files to either.
The input data file is merged with the selected PlanetPress Document.
The output is a PDF/VT with default quality settings. The metadata embedded within the PDF/VT is the one generated by the PlanetPress Document.
Properties
Note that the Connect Proxy tab is not present in the Create PDF/VT Action task properties, as this task does not communicate with the OL Connect Server.
- Documents: Select a specific PlanetPress Design document if you want all the jobs to be generated with that document.
- Recipient Node: Use the drop-down to select which level of the metadata is used as the "Recipient" node. The Recipient node defines each Record in the output when used with the Create Print Content task.
- Add job information to document: Check to add the 9 Job Info variables to the PDF/VT metadata at the root level.
