OLRP API Call
The OLRP API Call task allows you to make OLRP REST API calls to the OL Remote Print application.
Task Properties
General tab
  • OLRP API: Click the drop-down for the field Enter url, and select the desired API endpoint. The endpoint request method automatically updates.
  • Enter or update the JSON body. For some API calls, JSON code with placeholders is automatically added. Update the placeholders as appropriate.
  • Once the JSON body is complete, click Format to format the JSON body.
  • Connection:: Select the appropriate OLRP server. If necessary, the server's connection and authentication details can be viewed, edited, and saved, using the icons to the right of the sever selection. Once new connection and authentication details are saved, they are available to select for all OLRP plug-ins. Workflows are specific to OLRP servers, so the same plug-in can be used with the same or different properties for multiple servers.
