Query Jobs
The Query Jobs task allows you to query the OLRP server for jobs.
Task Properties
General tab
  • Output: Select the output type:
    • Store data attributes to XML. This results in an XML file.
    • Store data attributes to JSON. This results in a JSON file.
    • Enter a Page Size to limit the number of elements returned in a single request from the server. If nothing is entered, all jobs are returned. This may be large query and slow to run. Larger pages reduce requests to the server, but may be slow to run and use more server resources.
    • Enter the Page Index to select a specific page.
    • You can filter the query using the Job property table. Select one or more job properties, and enter the value or variable to match in the query. You can add or remove property and variable rows, and rearrange them, using the icons at the bottom of the list. The chart icon adds all properties to the list.
  • Connection:: Select the appropriate OLRP server. If necessary, the server's connection and authentication details can be viewed, edited, and saved, using the icons to the right of the sever selection. Once new connection and authentication details are saved, they are available to select for all OLRP plug-ins. Workflows are specific to OLRP servers, so the same plug-in can be used with the same or different properties for multiple servers.
