XML/JSON Conversion
This task can be found in the Plug-in Bar, under the Action tasks group.
The XML/JSON Action task converts an XML job file to JSON or a JSON job file to XML.
This task makes parsing XML/JSON files much simpler in a JavaScript environment and also allows processes to natively send JSON to a Connect template or data mapping configuration.
The current job file.
The current job file is converted from XML to JSON or from JSON to XML. When converting from JSON to XML, the encoding of the resulting XML file is always set to UTF-8 (which is the default format for JSON).
The converted job file gets the appropriate extension (.JSON or .XML).
If the current job file isn't JSON or XML (depending on the type of conversion requested), or if the conversion fails for any reason, the task raises an error and the current job file and metadata remain unchanged.
JSON to XML conversion
When a JSON source file contains a single JSON object, that object's key will be used as the root node name in the resulting XML file, and the root node will be populated with the data inside of the JSON object. In all other cases, a root node named 'root' will be added to the XML. It has the property "OL" with the value "RootObject" to define it as an array container. This property will be ignored when converting from XML to JSON.
Note: In addition to being valid, the JSON should follow naming rules for XML elements. For example, "adress_line_1:" is a valid key name in JSON, but it cannot be converted to a valid element name in XML because the colon is reserved for namespaces.
Although XML node names cannot start with a number, if any JSON keys start with a number, the task adds an underscore character. For example, the JSON key {"1" : "value"} converts to the XML <_1>value</_1>.
For XML naming rules and best naming practices, see: XML elements on W3Schools.
The output is the modified job file, which replaces the input job file. The metadata are reset.
General tab
  • Automatic detection: By default, the format of the job file is detected automatically. If the source file is a JSON file, it will be converted to XML. If it is an XML file, it will be converted to JSON.
    Uncheck this option to limit the task to one type of conversion and then select between:
    • XML to JSON: the task converts XML files to JSON.
    • JSON to XML: the task converts JSON files to XML.
  • Process XML attributes checkbox: Select to convert XML attributes into JSON objects.
    This selection is only applied if the source file is XML.
