Delete Capture OnTheGo Document
This task can be found in the Plug-in Bar, under the Connector tasks group.
The Delete Capture OnTheGo Document deletes a document from a Capture OnTheGo Repository, which stores documents that can then be retrieved by the Capture OnTheGo mobile application. It can be used, for example, to delete a document that has its expiration date set in the distant future but needs to be deleted as soon as an app user has submitted it.
This task can be added as an Action task (see Action tasks) or as a Condition Task. When used as a Condition task, the success of the delete operation determines whether the condition returns True or False.
In the network preferences, you can enable certificate validation for this task. See Network behavior preferences.
This task doesn't require an input file. It does need a Repository ID and password, and the ID of the document to delete.
This task connects to a Capture OnTheGo Repository and requests removal of a document with a given document ID.
The protocol used is TLS 1.3, or TLS 1.2 if the option Force outgoing encrypted connections to use TLS 1.2 or lower in the Preferences (Network behavior preferences) is checked.
When used as a Condition task, the success of the delete operation determines whether the task returns True or False.
The General tab is where you enter the connection information necessary to log on to the Repository to request removal of the specified the document.
- Server URL: Select the address of the COTG Server that you want the plugin to communicate with. (This option is only available if more than one COTG Server address has been defined.)
- Repository ID: Enter a valid Capture OnTheGo Repository ID.
- Password: Enter the password that corresponds to the Repository ID entered above.
- Document ID: Enter the ID of the document to delete from the Repository.
- Invert result: When the task is used as a Condition task, the success of the delete operation determines whether the condition returns True or False. Check this option to invert the result.
