File Store - Download File
This task can be found in the Plug-in Bar, under the OL Connect tasks group.
The File Store - Download File task downloads a file from the OL Connect File Store, using either a file name or File Store ID.
The task requires either the name of the file in the OL Connect File Store or its File Store ID.
Note: Neither OL Connect or OL Connect Workflow contain any inbuilt anti-virus functionality.
We recommend following security best-practices when uploading files to either.
The task tries to download the requested file from the OL Connect File Store by performing a call to the /rest/serverengine/filestore/file/{fileId} REST endpoint; see File Store Service: Download File in the REST API Cookbook.
The downloaded file becomes the current job file and retains the file name that it had in the OL Connect File Store.
- Filename or File Store ID: Enter the name of the file in the OL Connect File Store or its File Store ID. A File Store ID refers to a file or folder in the File Store.
OL Connect Proxy Tab
This tab is common to most OL Connect tasks and defines where to process the jobs sent through these tasks. When these fields are empty, they use the defaults set in the OL Connect preferences.
