Mark Connect Sets for Deletion
This task can be found in the Plug-in Bar, under the OL Connect tasks group.
The Mark Connect Sets for Deletion task indicates that an item in the OL Connect Database should be deleted the next time the Database Cleanup runs. This means that whatever item is set for deletion will no longer be available from the database.
The task requires a valid Metadata file containing items for deletion, including Job Sets, Content Sets and Data Sets. These can be created by the Execute Data Mapping, Create Print Content and Create Job tasks. Job Sets, Content Sets and Data Sets are also valid when obtained using the Retrieve Items task.
All sets currently active in the Metadata are set for deletion.
The same Metadata that is input.
OL Connect Proxy Tab
This tab is common to most OL Connect tasks and defines where to process the jobs sent through these tasks. When these fields are empty, they use the defaults set in the OL Connect preferences.
  • OL Connect Proxy Address: Enter the machine name or IP Address where the OL Connect Server resides.
  • Port: Enter the port to use to communicate with the OL Connect Server. Default: 9340
  • User name: Enter the user name expected by the OL Connect Server.
  • Password: Enter the password expected by the OL Connect Server for the above user name.
