Update Data Records
This task can be found in the Plug-in Bar, under the OL Connect tasks group.
The Update Data Records action task updates records in the OL Connect Database using values from the current Metadata or from JSON.
Each of the OL Connect Content Creation tasks can do the same, if the Update Records from Metadata option is enabled for that task.
The Update Data Records task can be useful when data needs to be updated multiple times before actually generating content, for instance when Postal Address Cleansing and Sorting is a two-pass process.
The current Job File is not used by this task. In order to update values in the OL Connect database, the task requires that the current Metadata contains record IDs, or that the given JSON contains a JSON Record Data List (see: Types of JSON in Workflow and ).
The records, of which the IDs are found in the source data, are updated either from the Metadata or from JSON.
Note: Date strings conforming to ISO 8601 are parsed and stored in the OL Connect database as Unix timestamps, i.e. the total number of seconds from the starting time of UTC (Universal Time, Coordinated) to the current time (with zero time zone offset). For instance: 1675950179.
The Job File is not changed by this task.
- Update Source: Select the data source from which the records in the OL Connect database will be updated.
- Metadata: Select this option to use the current content of the Metadata.
- JSON: Enter a JSON string, or a variable containing JSON. (See Variable task properties.) The task expects a JSON Record Data List; see: Types of JSON in Workflow.
OL Connect Proxy Tab
This tab is common to most OL Connect tasks and defines where to process the jobs sent through these tasks. When these fields are empty, they use the defaults set in the OL Connect preferences.
