File Store - Upload File
This task can be found in the Plug-in Bar, under the OL Connect tasks group.
The File Store - Upload File task uploads the current Job File to the OL Connect File Store.
The task always takes the current Job File as input file. If you want to upload an external file, first use the Load External File plugin to load that file as the Job File.
The task tries to upload the current job file to the OL Connect File Store by making a call to the /rest/serverengine/filestore/DataFile REST endpoint; see File Store Service: Upload File in the REST API Cookbook.
When a file is uploaded to the OL Connect File Store, it is automatically assigned a File Store ID. The task stores the returned File Store ID in the specified variable.
This task does not modify the Job File.
  • Filename: Enter the file name or a JobInfo, local or global variable that contains the file name, to use when saving the file in the OL Connect File Store. The default is %f, the name of the job file. Right-click the field to select another variable. When you specify %o as the file name, the file in the OL Connect File Store will have the same name as the original file.
  • Save File Store ID in variable: Select the variable in which to store the File Store ID that is returned after a file has been successfully uploaded to the File Store. This ID can be used to download or delete the file from the OL Connect File Store.
  • Mark as permanent: When this option is checked, the file will never be removed automatically by OL Connect's Clean-Up Service. Non-permanent files may be removed if there are no remaining references to them in the OL Connect Database. (See: Clean-Up Service preferences.)
OL Connect Proxy Tab
This tab is common to most OL Connect tasks and defines where to process the jobs sent through these tasks. When these fields are empty, they use the defaults set in the OL Connect preferences.
  • OL Connect Proxy Address: Enter the machine name or IP Address where the OL Connect Server resides.
  • Port: Enter the port to use to communicate with the OL Connect Server. Default: 9340
  • User name: Enter the user name expected by the OL Connect Server.
  • Password: Enter the password expected by the OL Connect Server for the above user name.
