Royal Mail 2D Mailmark Settings
Royal Mail 2D Mailmark Barcodes are a variant of 2 dimensional Datamatrix barcodes. They are used by the British Royal Mail postal service. They contain the address of the receiver, encoded in alpha-numeric format (0-9, A-Z).
  • General group:
  • Position group:
      The orientations would look like this (using text and a QR barcode as the examples), in a Portrait document:
  • Royal Mail 2D Properties group:
    • Module Width: The size of each column and row within the barcode. Value must be between 0.5 mm and 0.7 mm.
    • Preferred Version: Select the preferred size of the barcode in terms of rows by columns.
      Note: Depending on the information being embedded, this entry may be overridden if the specified size is not big enough to contain the barcode information.
  • Tilde processing
