Control Script: Setting a Print section's background
In the Print context, an image file can be used as a Print section's background; see Using a PDF file or other image as background.
If you want the section background to be switched automatically, depending on the value of a data field, you need a Control Script. There is a Script Wizard that can generate that script for you, provided that certain conditions are met; see: Dynamic Print section backgrounds.
Otherwise, you will have to write the Control Script yourself. This topic explains how to write a Control Script that sets a Print section's background.
Note that the settings made in a Control Script take precedence over the settings made in the Print Section Properties dialog.
Note: Encrypted PDF files are not supported in PDF pass-through mode.
Note: Any non-content features in the original PDF will get stripped out of the original PDF. These include document navigation (outline), local links, hyperlinks, annotations (markup annotations, comments, etc.), digital signatures, multimedia features, interactive forms, and tagged PDF features (marks in the page content will stay, but the logical structure is gone).
Setting a background in script
The Control Script should first enable a background on the section, in case an initial background wasn't set via the user interface. This is done by setting the source type for the background of the section to either DataMapper PDF orResource PDF (see BackgroundResource). For example:
Copy
merge.template.contexts.PRINT.sections['Policy'].background.source =
BackgroundResource.RESOURCE_PDF;
merge.template.contexts.PRINT.sections['Policy'].background.source = BackgroundResource.RESOURCE_PDF;
For a DataMapper PDF, nothing else has to be done to set the background.For a Resource PDF, the Control Script should specify a path, for example:
Copy
var resourceUrl = 'images/policy-' + record.fields.policy + '.pdf';
merge.template.contexts.PRINT.sections['Policy'].background.url = resourceUrl;
Positioning, scaling and rotating the background
After a background has been selected, it can be positioned, scaled and rotated, using properties of the background object; see background.
To position the background, for example, set the section's background.position:
Copy
activeSection.background.position = MediaPosition.FIT_TO_MEDIA;
For all possible positions, see MediaPosition.
Setting a page range in script
When a PDF that serves as a dynamic section background has multiple pages, you can specify a range of pages to be used, in a control script.
Put the number of the first page in the range in the section's background.start field and the last page in background.end.
The following script sets the page range from 2 to 5:
Copy
merge.template.contexts.PRINT.sections['Policy'].background.start = 2;
merge.template.contexts.PRINT.sections['Policy'].background.end = 5;
Setting a page range automatically sets background.allPages to false (see background).
On the other hand, when you first define a page range and then set background.allPages to true, this disables the page range.
Tip: You could use the resource() function to check the number of pages or for example the page height and width before setting it as a background (see resource()).
This script sets a background on a Print section using absolute positioning.
Copy
var activeSection = merge.template.contexts.PRINT.sections['Section 1'];
activeSection.background.source = BackgroundResource.RESOURCE_PDF;
activeSection.background.url = "images/somepage.pdf";
activeSection.background.position = MediaPosition.ABSOLUTE;
activeSection.background.left = "10mm";
activeSection.background.top = "10mm";
Copy
