Data Matrix
Data Matrix is one of the types of barcodes that can be added to a template; see Barcode.
Data Matrix barcodes can be read even if they are partially damaged, because of the error correction codes added to them (according to the ECC200 standard).
This topic lists the properties and output options of the Data Matrix barcode. For the properties of other barcode types, see Barcode type and properties.
Note: Tilde characters in the data are processed as special characters (see the Java4less Barcodes Guide to learn what the tilde character can be used for).
Any tilde that needs to be included in the output must be escaped by adding another tilde (either "~~", or "7E7E" if the Hex input option is enabled). This can be done with a replace() call in the Barcode script, after expanding the script.
Barcode properties
Hex Input
For optimized mailings, German Post requires the supplied data for the Data Matrix barcode to be hexadecimal input.
Check this option if your input data is a hexadecimal code. The incoming data will be interpreted as hexadecimal input and decoded to ASCII before passing the string to the Barcode library.
Dots Per Pixels
Type the number of dots per pixel. To optimize barcode quality a Data Matrix symbol should not be printed with dots smaller than 4 pixels.
Encoding
The data represented in the symbol can be compressed using of the following algorithms.
  • ASCII is used to encode data that mainly contains ascii characters (0-127).
  • C40 is used to encode data that mainly contains numbers and UPPER-case characters.
  • Text is used to encode data that mainly contains numbers and lower-case characters.
  • Base256 is used to encode 8 bit values.
  • Auto Detect automatically detects the data content and encodes using the most appropriate method.
  • None does not use any encoding.
Note: For general information on encoding, see https://en.wikipedia.org/wiki/Data_Matrix#Encoding.
Please check with the manufacturer of the barcode reader if any specific encoding is required.
Preferred format
Use the drop-down to select the size of the Data Matrix.
Scale
  • Proportional: The barcode is stretched up to where it fits either the width or height of the parent box, whichever requires the less stretching.
Tilde processing
Barcode output
Color
Output format
  • SVG: Vector format. This is usually of higher quality, but may take longer to generate. It is not compatible with Email output.
  • PNG: Binary rasterized format. This has a slightly lower quality than SVG but is usually generated faster. It will display properly in Email output.
