Royal Mail 2D Mailmark
Royal Mail 2D Mailmark is one of the types of barcodes that can be added to a template; see Barcode.
This topic lists the properties and output options of the barcode type Royal Mail 2D Mailmark. For the properties of other barcode types, see Barcode type and properties.
Barcode properties
Module width
The recommendation is to print these barcodes with a module size of 0.5 mm, which equates to 6 dots when printed at 300dpi. The maximum module size for printing is 0.7 mm.
Preferred version
Use the drop-down to select the size of the barcode, in a number of modules. The actual size of the barcode can be 12 mm x 12 mm up to 22.4 mm x 22.4 mm, depending on the preferred version and the module width.
Scale
  • Proportional: The barcode is stretched up to where it fits either the width or height of the parent box, whichever requires the less stretching.
Tilde processing
Barcode output
Color
Output format
  • SVG: Vector format. This is usually of higher quality, but may take longer to generate. It is not compatible with Email output.
  • PNG: Binary rasterized format. This has a slightly lower quality than SVG but is usually generated faster. It will display properly in Email output.
