Codabar Settings
Codabar barcodes support the following data: 0-9 - $ : / . + plus the optional specification of start/stop characters.
  • General group:
  • Position group:
    • The orientations would look like this (using text and a QR barcode as the examples), in a Portrait document:
  • Codabar Properties group:
    • Height: Enter the Barcode height in either metric (cm/mm), inch (in) or point (pt) values.
    • Module Width: Specifies the width of the narrow bars. Changing this value to a higher value will generally make the Barcode bigger.
    • Bar width ratio: Set the Barcode bar width.
    • Default start symbol: Use the drop-down to select the optional Barcode start character, which defines the encoding mode.
    • Default stop symbol: Use the drop-down to select the Barcode stop character, which defines the encoding mode.
      • Print human readable text: Check to add a textual version of the Barcode data.
      • Placement: Use the drop-down to select whether to place the human readable text above or below the Barcode.
      • Font name: Use the drop-down to select the font with which to display the human readable text.
      • Font size: Enter a font size for the human readable text.
      • Display start/stop symbols checkbox: Adds the stop/start symbols to the Barcode text.
  • Process Tilde:
