Code 39 Settings
Code 39 is a discrete, self-checking barcode that is also known as "Alpha39", "Code 3 of 9" (often abbreviated to "3 of 9"), "Code 3/9", "Type 39", "USS Code 39" and "USD-3".
Code 39 data should contain no more than 20 digits from within the following range: Numeric digits: (0-9), upper-case letters (A-Z), seven special characters (- . space $ / + %) and the start/stop asterisk (*) character.
If the Extended character set is chosen, then lower-case letters (a-z) and other special ASCII characters can also be included.
Settings
  • General group:
  • Position group:
    • The orientations would look like this (using text and a QR barcode as the examples), in a Portrait document:
  • Code 39 Properties group:
    • Height: Enter the Barcode height in either metric (cm/mm), inch (in) or point (pt) values.
    • Use extended character set: Check to use the Code 39 Extended character set. This extends the range of supported data to include the full ASCII character set. This adds support for lower case letters (a-z) and the full range of ASCII punctuation and special characters.
    • Module Width: Specifies the width of the narrow bars. Changing this value to a higher value will generally make the Barcode bigger. The smallest Module Width is 0.19mm (high density).
    • Bar width ratio: Set the Barcode bar width.
      • Checksum: Use the drop-down to select how to deal with the Barcode checksum:
      • Ignore: Ignore checksum calculations.
      • Auto: Add a checksum character to the Barcode if the initial value does not validate. This is the default value.
      • Check: Verify the Barcode has a valid checksum.
      • Add: Calculate and add a checksum character to Barcode, regardless of current value.
      • Print human readable text: Check to add a textual version of the Barcode data.
      • Placement: Use the drop-down to select whether to place the human readable text above or below the Barcode.
      • Font name: Use the drop-down to select the font with which to display the human readable text.
      • Font size: Enter a font size for the human readable text.
  • Process Tilde:
    Check this option to process tilde characters in the data as special characters.
    With this option checked, any tilde that needs to be included in the output must be escaped by adding another tilde: ~~.
