Data Matrix settings
A Data Matrix barcode is a high-density, two-dimensional (2D) matrix barcode which supports encoded text, numbers, files and digital data.
Note: In order to create a GS1 compliant Data Matrix barcode, the barcode data must meet the following requirements:
  • The barcode data must start with a leading FNC1 character. Either ~1 or ~d232.
  • The GS1 Application Identifiers (AI) must be used for all data.
    The function code ~1 must be used as field separator for variable length AI elements.
  • Only ASCII characters should be used.
  • General group:
  • Position group:
    • The orientations would look like this (using text and a QR barcode as the examples), in a Portrait document:
  • Data Matrix Properties group:
    • Module Width: Specifies the width of the narrow bars. Changing this value to a higher value will generally make the Barcode bigger.
    • Encoding: The data represented in the symbol can be compressed using one of the following algorithms:
      • Auto: Automatically detect the data content and encodes using the most appropriate method. This is the default option.
      • ASCII: is used to encode data that mainly contains ASCII alphanumeric characters (ASCII 0-127). Use where Barcode size is a concern and where the data is alphanumeric.
      • Base 256: used to encode 8-bit values.
      • C40: used for data that mainly consists UPPER-case alphabetic letters and numbers.
      • Text: used for data that mainly consists of lower-case alphabetic letters and numbers.
      • None: Does not use any encoding.
      Note: For general information on encoding, see https://en.wikipedia.org/wiki/Data_Matrix#Encoding.
      Please check with the manufacture of the barcode reader if any specific encoding is required
    • Format: select the Barcode size format from the drop-down list .
  • Process Tilde:
    Check this option to process tilde characters in the data as special characters.
    With this option checked, any tilde that needs to be included in the output must be escaped by adding another tilde: ~~.
    Note: The following tilde codes are supported:
    • ~1 = FNC1 character (for GS1 DataMatrix barcodes)
    • ~2 = Structure Append
    • ~3 = Reader programming
    • ~5 = Macro5
    • ~6 = Macro6
    • ~7 = ECI expressions
