The Data Model
The Data Model is the structure of records into which extracted data are stored. It contains the names and types of the fields in a record and in its detail tables. A detail table is a field that contains a record set instead of a single value. The Data Model is shown in the Data Model pane, filled with data from the current record.
The Data Model is not related to the type of data source: whether it is XML, JSON, CSV, PDF, Text, or a database does not matter. The Data Model is a new structure, designed to contain only the required data.
About records
A record is a block of information that may be merged with a template to generate a single document (invoice, email, web page...) for a single recipient. It is part of the record set that is generated by a data mapping configuration.
In each record, data from the data source can be combined with data coming from other sources.
Records can be duplicated by setting the number of copies in a script (see record). Duplicates are not shown in the Data Model.
Creating a Data Model
A Data Model is created automatically within each data mapping configuration, but it is empty at the start. To fill it you could use another Data Model (see Importing/exporting a Data Model) or start creating a data mapping workflow (see Data mapping workflow).
To learn how to add and edit fields, see Fields.
To use a Data Model in another data mapping configuration, or to use it in a Designer template without a data mapping configuration, you have to export that Data Model and import it into a data mapping configuration or template.
Importing and exporting Data Models is done from within the Data Model pane, using
 Import and
 Export icons in the
 View menu at the top right of the Data Model.
For information about the structure of the exported Data Model file, see Data Model file structure.
When you import a Data Model, it appears in the Data Model pane where you can see all the fields and their types.
Instead of a Data Model file, you can import a JSON file, or a Connect file that contains a Data Model. The file's data model structure will be displayed in the Data Model pane.
You can delete or add fields, or change their type. Once the Data Model is imported and all the fields are properly set, all you need to do is extract the information from the active data sample (see Extracting data).
Note:
- Imported Data Model fields always overwrite existing field properties when the field name is the same (although they will still be part of the same Extract step). Non-existent fields are created automatically with the appropriate field settings. The import is case-insensitive.
 - All imported Data Model fields are marked as required in the Data Model (indicated with an asterisk (*) next to their names). This is to prevent them from being removed, as the DataMapper immediately discards non-required fields that are not referenced by any Extract step.
Editing the Data Model
The Data Model is generally constructed by extracting data; see Extracting data.
Empty fields and data tables can be added via the contextual menu; see Adding empty fields via the Data Model pane.
Editing fields
You can modify the fields in the Data Model via the contextual menu that opens when you right-click on something in the Data Model pane. For an explanation of the options in this menu, see Data Model contextual menu.
As long as a field or data table, added via the Data Model pane, remains empty, it can be edited (renamed, deleted etc.) via the contextual menu.
Fields in a Data Model that are actually used in the extraction workflow cannot be edited via the contextual menu of the Data Model pane. They are related to a step in the extraction workflow and are edited via the Step properties pane instead (see Editing fields).
Ordering and grouping fields in the Data Model
To make the Data Model clearer and more manageable, you can change the order of the fields in it and create groups of fields. All grouping and ordering information is saved in the data mapping configuration, so that when you reopen it, the Data Model will look the same.
Note that these changes have no impact on the order in which data are extracted, or on the final records in the OL Connect database. They only help you organize the Data Model visually.
This also means group names are not used in scripts; fields and detail tables are accessed directly through the record object (see the Designer Script API and DataMapper Scripts API).
To change the order in which data are extracted, see Renaming and reordering fields in an extraction step.
Moving fields
To move a field, a group of fields or a detail table, you can simply drag and drop it to some other place in the Data Model.
Alternatively, you can right-click the field, group or detail table and select one of the options in the Move menu, to move it up or down within the list or group.
Fields cannot be moved into another table. However, inside a table they can be moved up or down.
Grouping fields
To group one or more fields, select the field(s), right-click and select Add group. It is also possible to create groups within groups; this is done in the same way.
To move a field into an existing group you can simply drag and drop it into the group or onto the name of that group.
To delete a group, right-click it and select Ungroup. The fields will be moved up one level in the structure. To move a field out of an existing group you can also simply drag and drop it out of that group.
To delete an empty group, right-click it and select Delete.
Using the Data Model in templates
The Data Model is what enables you to create personalized templates in the Designer module.
You can drag & drop fields from the Data Model into the template that you are creating (see Variable data in the text). For this, you need to either have a template and a data mapping configuration open at the same time, or import a Data Model (see Importing/exporting a Data Model).
The Data Model is reusable, meaning that it can be shared amongst different template layouts and output types.
Different data mapping configurations could use the same Data Model, allowing a template to be populated with data from different sources and formats, without the need to modify the template (see Importing/exporting a Data Model).
In Workflow, when a data mapping configuration is used to extract data from a data source (see Data mapping configurations), the extracted data is stored in a record set in the OL Connect database.
Adding fields and data via Workflow
The Data Model is not extensible outside of the DataMapper. When it is used in Workflow - as part of a data mapping configuration - the contents of its fields can be updated but not its structure. There are a number of instances however, where data may need to be added to the data model after the initial data mapping operation has been performed. For instance, you might need to add a cleansed postal address next to the original address, or retrieve a value from a database and add it to the record.
Runtime parameters
Runtime parameters can pass values from an automation tool - OL Connect Workflow, usually - to a template, data mapping configuration or Job Preset. The actual values of the parameters may be different from one time that a process runs to the next, which means the output could be different even when the same template, data mapping configuration and/or Job Presets are used.
See Properties and runtime parameters to learn how to use them in a data mapping configuration.
ExtraData fields
Before the introduction of runtime parameters, empty fields needed to be added in advance to provide space in the Data Model for Workflow to store data. For convenience, one field called ExtraData was (and is) automatically created at every level of each data record. That means the record itself gets an ExtraData field, and each detail table also gets one.
By default the field is not visible in the DataMapper's Data Model, because it is not meant to be filled via an extraction. It can be made visible using the
 Show ExtraData Fields icon in the
 View menu at the top of the Data Model. This icon is only  visible if the View ExtraData option has been checked in the preferences: Window > Preferences > Data Model.
Workflow process
ExtraData fields can be filled in a OL Connect Workflow process as follows:
Use an Execute Data Mapping task or Retrieve Items task to create a record set. On the General tab select Outputs records in Metadata.
Add a value to a field in the Metadata using the Metadata Fields Management task.
Data added to the _vger_fld_ExtraData field on the Document level will appear in the record's ExtraData field, once the records are updated from the Metadata (in the next step).
Other fields have the same prefix: _vger_fld_. -
Update the record/s from the Metadata. There are several ways to do this. You could, for example:
Use the Update Data Records plugin.
Add an Output task and check the option Update records with Metadata.
Select Metadata as the data source in the Create Preview PDF plugin.
Note: Many of these actions can also be performed using REST calls.
Please refer to OL Connect Workflow documentation for more information about the plugins involved: Workflow's Online Help.
