Code 128 Settings
Code 128 is a high-density barcode, used for alphanumeric or numeric-only barcodes. It supports all 128 ASCII characters.
General group:
Position group:
- Code 128 Properties group:
 - Height: Enter the Barcode height in either metric (cm/mm), inch (in) or point (pt) values.
 - Module Width: Specifies the width of the narrow bars. Changing this value to a higher value will generally make the Barcode bigger.
Print human readable text: Check to add a textual version of the Barcode data.
- Process Tilde:
Check this option to process tilde characters in the data as special characters.
With this option checked, any tilde that needs to be included in the output must be escaped by adding another tilde: ~~.
