Royal Mail 4 State (CBC) Settings
Royal Mail 4-State Customer Bar Code (CBC) is also known as the Royal Mail 4-State Customer Code (RM4SCC or RoyalMail4SCC). It is used by the British Royal Mail postal service. The barcode contains an address, encoded in alpha-numeric format (0-9, A-Z).
General group:
Position group:
Royal Mail Properties group:
Track height: The height of the small vertical centre bars, in metric (mm/cm). Value must be between1.02 mm and 1.52 mm.
Full bar height: Height of the tallest vertical bars, in metric (mm/cm). Value must be between4.22 mm and 5.84 mm.
The ascender and descender bar heights are automatically calculated based upon the Full and Track bar heights. -
Module width: Thickness of each bar in the Barcode, in metric (mm/cm). Value must be between0.38 mm and 0.63 mm.
Module spacing: The spacing between each bar, in metric (mm/cm). Value must be between0.38 mm and 0.63 mm.
- Process Tilde:
