Mark Position Options
This page appears as part of the Advanced Print Wizard and the print Output Preset wizard.
The Mark Position Options page displays a Preview of the output and the possible locations to place the inserter marks. The initial settings are determined by the selections made within the Inserter options page.
You can move back and forward between these two pages to perfect the settings, or you could move the inserter mark box to the desired location on the preview.
Preview box:
The pink area displays the areas of the page where inserter marks can be positioned.
The small checkered box displays the current location of the inserter marks. This box is selectable and can be dragged to the desired location within the printable (pink) areas.
If the box is placed outside the printable areas the page will display an error and prevent attempts at leaving the page.
Below the Preview box are buttons which allow control of the Preview box. The selections that can be made are:
First Page: Click to jump to the first page. -
Previous Page: Click to move to the previous page. -
Next Page: Click to move to the next page. -
Last Page: Click to jump to the last page. -
Show Page: Use the up and down arrows or type a page number to display a specific page within the document.
Zoom in/out: Click to zoom in or out by 25% -
Zoom Level: Use the drop-down to select a predefined level or enter a zooming percentage.
Advanced Printing Wizard and Output Preset navigation options
Print button (Advanced Print Wizard only) or Finish button (Output Preset Wizard only):
Cancel button: Cancels the Print Wizard, without creating any printout or altering Preset.
