Using the wizard for databases
The DataMapper wizard for database files helps you create a data mapping configuration for a database file. The wizard extracts the data in one extraction step.
The wizard cannot create detail tables. If the file contains transactional data, create the data mapping configuration without a wizard (see Creating a new data mapping configuration), and add the extraction steps yourself.
Opening a database file with a wizard
There are two ways to open an XML file with a wizard: from the Welcome screen or from the File menu.
From the Welcome screen
Open the OL Connect Welcome page by clicking the
Home icon at the top right or select Help > Welcome on the menu. -
Click New at the left, then click Data at the right.
Select From database.
Use the drop-down to select the database type.
Click Next.
From the File menu
Click the Data mapping Wizards drop-down and select From databases.
Click Next.
Click Next.
Wizard settings for a database file
After opening a database file with a wizard there are a number of settings to make, depending on the database type (see below).
On the last page of the dialog, click Finish to close the dialog and open the actual data mapping configuration.
Note: After creating the initial data mapping configuration you may use a custom SQL query via the Input Data Settings; see Data source settings.
Tip: The Sort on option, combined with the Stop data mapping option of the Action step, allows to process only a group of items without having to examine all records. (See also: Action step properties.)
MariaDB, MySQL, SQL Server or Oracle
Server: Enter the server address for the database.
Port: Enter the port to communicate with the server. The default port is 3306.
Database name: Enter the exact name of the database from where the data should be extracted.
User name: Enter a user name that has access to the server and specified database. The user only requires Readaccess to the database.
Password: Enter the password that matches the user name above.
Table name: The selected database is a set of related tables composed of rows and columns corresponding respectively to source records and fields. Select a table from which you want to extract data.
Encoding: Choose the correct encoding to read the file.
Sort on: Select a field on which to sort the data, in ascending (A-Z) or descending (Z-A) order. Note that sorting is always textual. Even if the selected column has numbers, it will be sorted as a text.
Microsoft Access
Password: Enter a password if one is required.
ODBC Data Source
Caution: ODBC drivers do not all work with Java applications. Since OL Connect is a Java application, it is strongly recommended to use JDBC instead.
Source: Use the drop-down to select a 64-bit ODBC System Data Source. OL Connect is a 64-bit application and cannot access 32-bit data sources.
Advanced Configuration Check this option to enter authentication details and, if applicable, additional properties. Once checked, more options appear.
ODBC source is MSSQL: Check this option if the ODBC source is MSSQL (SQL Server). Now you can select the authentication type:
Windows authentication: Select to use the Windows username and password that are used by the Connect Service. You cannot enter any additional properties as all connection details are managed by the windows authentication settings.
SQL Server authentication: Select to use the Username and Password entered below to connect to the SQL Server:
Username: Enter the SQL Server user name.
Password: Enter the password for the above user name.
You can also select a Quote character. This character, also known as a wrap character, generates a default query for SELECT * from 'TABLE'. The character wraps the table name in the selection query. This character is database-specific and must be supplied by the user. The blank character means that there is no wrapping character for the table name.
You can also enter Additional properties required for the connection. These are key/value parameters included in the connection string generated when the ODBC connection is created. For example, in the current implementation, the MSSQL database requires the
MARS_Connection=yesparameter, which is hard-coded. Some custom databases may require additional parameters.-
Each row of the grid represents a pair of custom key/value parameters for the connection string.
To enter a pair of parameters, click the green database add icon to the right of the table.
To delete a pair of parameters, click the row for the parameters to delete, and then click the red database delete icon to the right of the table.
If ODBC source is MSSQL is not checked, for example, to support some versions of the DB2 OBDC driver, you enter a Username, Password, and Advanced settings.
Note: The connection string, built from the entries made and options selected, displays at the bottom of the window. It cannot be edited directly.
JDBC
Note: Since JDBC can connect to multiple types of databases, a specific database driver and path to this driver's JAR file must be specified.
JDBC Driver: Use the drop-down to select which JDBC Driver to use for the database connection.
JAR file path: Enter a path to the JAR file that contains the appropriate driver for the database.
Server: Enter the server address for the database server.
User name: Enter a user name that has access to the server and specified database. The user only requires Read access to the database.
Advanced mode: Check to enable the Connection String field to manually enter the database connection string.
Connection string: Type or copy in your connection string.
Note: To instruct the SQL Server driver to not use encryption, the ";encrypt=false" parameter needs to be present in the connection string. For more information see Known Issues.
