System requirements
These are the system requirements for OL Connect 2026.1.
Operating system
Any 64-bit Windows Desktop or Server version which is in its mainstream support period, as defined by https://learn.microsoft.com/en-us/lifecycle/.
New versions of Windows are supported within the first 6 months of their commercial release.
Supported virtual environments
Amazon Web Services (AWS)
Google Cloud Platform
Microsoft Hyper-V/Azure
Nutanix AHV
VMWare vCenter/vSphere
Minimum system requirements for OL Connect / Workflow
As with any software application, these minimum hardware requirements represent the most basic hardware on which the software will run:
CPU: at least a 64-bit CPU with 4 physical cores.
RAM: at least 16 GB.
Storage: at least 100GB available on fast SSD for the system drive (by default, this means the C drive).
Networking: at least 1Gbps.
Rules of thumb
When installing on multiple computers, keep the following rules of thumb in mind:
The more logical processors, the better.
Higher CPU clock speeds are recommended: 24 logical processors @3GHz may perform better than 32 logical processors @2.2 GHz, depending on the workload.
For each additional logical processor, plan to add 2 GBs of RAM.
The number of logical processors is in direct relation with the number of OL Connect engines that can efficiently run concurrently.
The specifications
Keep in mind, however, that they may not represent the optimal configuration for your particular application.
