Address Block special formats
In most Address Block formats, the expected contents of the address fields are self-explanatory and it is easy to match each address field with the appropriate data field.
Some Address Block formats contain address fields where additional information is required to match the field with the appropriate data field, and ensure the data field is formatted correctly.
Additional information is available for fields in the following Address Block formats:
Tip: Several postal services use barcodes, which may be part of an address block. For more information about postal barcodes, see Additional Barcode Options.
For more information about using Address Blocks, see Address Block
Germany DV-Freimachung
The information below is a general guideline. Senders should review field requirements with Deutsche Post, as the mailing contract may specify contents for these fields. Additional information is available at DV FREIMACHUNG Downloads.
DV Absender: The sender details. This is the return address, on one line. PO Box addresses or dedicated customer postal codes, for example, 80324 München, meet this requirement.
DV DMC: The data matrix code, or barcode. This generates and displays the barcode in the address, and controls the display of the PREMIUMADDRESS information based on values in the data matrix code.
DV Entgelt: The postage amount. For items charged at per kilo rates, this is the net item charge plus the net list price for additional services, if applicable.
DV Frankier-ID: The franking ID is unique for every mail item. It consists of a subscription number (2 digits), the customer number of the sender (7 digits without any check digit), the item ID (10 digits, comprising a billing number and a consecutive item number), and a check digit (1 digit), in hexadecimal form.
DV Infozeile 1: The first information line is optional and available for senders to use for their information, or the sender's contract may require information here. Content must be between asterisks (*), and asterisks can be used as field separators.
DV Infozeile 2: The second information line is optional and available for senders to use for their information, or the sender's contract may require information here. Content must be between asterisks (*), and asterisks can be used as field separators.
DV Infozeile 3: The third information line is optional and available for senders to use for their information, or the sender's contract may require information here. Content must be between asterisks (*), and asterisks can be used as field separators. The third information line can only be used if the mailing address is four lines. If the mailing address is five lines, this third information line is not available.
DV MM.JJ: The posting date, entered as month and year, with a period between them. For example, for October 2025, enter 10.25
DV Produkt: Manages the display of the product description for DIALOGPOST or DIALOGPOST INTERNATIONAL when the referenced field contains one of the two descriptions. To display a different or custom product description, use DV Produkt Sonderfall.
DV Produkt Sonderfall: This optional field overrides the content of the DV Produkt field with any custom product description. Leave this field empty if you are using the regular behavior of the DV Produkt field.
Netherlands
KIX: This is for the KIX barcode (also known as a customer index code, Klantenindex, or Dutch KIX 4-State). For more information, see KIX Code (PostNL) Settings
Printregel: This field is for the Print Line, also known as the Sorting Line. It is used when mail consignments are sorted. Sorting is required for shipments of more than 2,500 items, and recommended for smaller shipments. The line consists of numbers, upper case letters, and hashtags, without spaces. The line is unique to every mail item and provides information about the consignment and the item's place in the consignment. The Print Line begins with the Coding Line, which provides a code for each address and handover location. There are no spaces in the Print Line.
USA ASE+IMb / USA ASE+IMb top
ASE : This is for the Ancillary Service Endorsement, generally used for senders to receive updates for addresses. For more information about the available endorsements, see USPS Ancillary Service Endorsements. Available endorsements to enter are:
Electronic Service Requested. Handling instructions are predefined in the ACS mailer profile, and this request must also be part of the Intelligent Mail barcode. -
Address Service Requested. Depending on the class of mail and the time since an address has changed, the mail is forwarded or returned, with or without fees. New address notification or reason for nondelivery is also provided. Depending on the contract with USPS, this information may also be required in the Intelligent Mail barcode. -
Return Service Requested. Mail is returned, with the new address or reason for nondelivery. Priority and First Class mail is handled at no charge, while marketing mail and parcels are charged at the normal rate. -
Change Service Requested. Undeliverable mailed is disposed of, and the new address or reason for nondelivery is supplied. Rates vary. Depending on the contract with USPS, this information may also be required in the Intelligent Mail barcode. -
Forwarding Service Requested. Depending on the class of mail and the time since an address has changed, the mail is forwarded or returned, with or without fees. -
Temp-Return Service Requested. This is only available for Priority and First Class mail. The mail is returned with a new address or the reason for nondelivery, however if the address change is temporary, the mail is forwarded, with no notification to the sender. -
If no endorsement is entered, marketing mail is disposed of. Other mail is handled as
IMb: This is for the USPS Intelligent Mail barcode. Depending on the Address Block selected, the barcode can be placed above or below the address. For more information, see US Postal Service IMb Settings.
