Finding the Data Records in a Data Set
Problem
You want to obtain a list of all the previously created Data Records contained within a specific Data Set potentially for use in a Content Creation operation.
Solution
The solution is to create a request using the following URI and method type and submit it to the server via the Data Set Entity REST service:
Example
HTML5
dse-get-datarecords.html
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<title>Get Data Records for Data Set Example</title>
<script src="js/dse-get-datarecords.js"></script>
</head>
<body>
<h2>Data Set Entity Service - Get Data Records for Data Set Example</h2>
<form>
<fieldset>
<legend>Inputs</legend>
<div>
<label for="dataset">Data Set ID:</label>
<input id="dataset" type="text" placeholder="1234" required>
</div>
<div>
</div>
</fieldset>
</form>
</body>
</html>
JavaScript/jQuery
/* Data Set Entity Service - Get Data Records for Data Set Example */
(function ($, c) {
"use strict";
c.setupExample();
event.preventDefault();
if (!c.checkSessionValid()) { return; }
var dataSetId = $("#dataset").val();
$.ajax({
type: "GET",
url: "/rest/serverengine/entity/datasets/" + dataSetId
.done(function (response) {
c.displayHeading("Data Record IDs for Data Set '" + dataSetId + "'");
c.displaySubResult("Plain", c.jsonIDListToPlain(response));
c.displaySubResult("JSON Identifier List", c.jsonPrettyPrint(response));
}(jQuery, Common));
Screenshot & Output
Usage
To run the example simply enter the Data Set ID and select the Submit button to request a list of the all the data records contained within the specific data set in the server.
The resulting list will then be returned and displayed to the Results area in both Plain list and formats.
Further Reading
See the Data Set Entity Service page of the REST API Reference section for further detail.
