Get Progress of Operation
Retrieves the progress of a running All-In-One operation of a specific operation ID.
Request takes no content, and on success returns a response containing the current value of operation progress (values ranging from 0 – 100, followed by the value of 'done' on completion).
Request
| Method Type: |
GET |
| URI: | |
| Content: | – |
| Content Type: |
| Add. Headers: |
Parameters
Path
| Name | Required | Type | Default Value | Description |
| operationId |
Operation ID of All-In-One operation |
Response
Success
| 200 OK |
Progress value of All-In-One operation | text/plain | – | Progress of operation successfully retrieved |
Error
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
