Get Result of Operation
Retrieves the final result of a completed All-In-One operation of a specific operation ID.
Request takes no content, and on success returns a response (depending on the All-In-One configuration) containing either:
- the ID of the Data Set, Content Set or Job Set entity produced, or
- the absolute paths of the final output files produced (multiple spool files) or the content of a final output file (single spool file).
Request
| Method Type: |
POST |
| URI: | |
| Content: | – |
| Content Type: |
| Add. Headers: |
Parameters
Path
| Name | Required | Type | Default Value | Description |
| operationId |
Operation ID of All-In-One operation |
Response
Success
| 200 OK |
Either:
application/octet-stream |
If the
Result of completed operation successfully retrieved |
The "X-Result-Type" header could have one of the following values:
"Data-Set-ID" - the entity contains a dataSetID (only data mapping operation requested)
"Content-Set-ID” - the entity contains a contentSetID (last operation: content creation)
"Job-Set-ID" - the entity contains a jobSetID (last operation: content creation)
"Output-Streamed" - the entity contains a streamed output file (last operation: content creation)
"Output-Local-Filepath" - the entity contains absolute path of output file (last operation: content creation)
"Output-Managed-Info" - the entity contains ID of persisted output file(s) (last operation: content creation)
Error
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
404 Not Found |
application/json |
Operation not found in Server |
