Upload Template
Submits a template to the File Store.
Request takes zipped file data as content, and on success returns a response containing the new Managed File ID for the template.
Request
| Method Type: |
POST |
| URI: | |
| Content: | Template (File) |
| Content Type: |
application/zip |
| Add. Headers: |
Parameters
Query
| Name | Required | Type | Default Value | Description |
| filename | – | – | – |
The file name of the template to be uploaded |
persistent |
false |
Whether the template to be uploaded will be persistent in File Store |
Response
Success
| 200 OK |
Managed File ID (or Name) | text/plain | – | Template successfully uploaded to File Store |
Error
400 |
application/json |
Request contains no data for upload to File Store. |
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
