Cancel an Operation
Requests the cancellation of a running Output Creation operation of a specific operation ID.
Request takes no content, and on success returns a response with no content.
Request
| Method Type: |
POST |
| URI: |
/rest/serverengine/workflow/outputcreation/cancel/{operationId} |
| Content: | – |
| Content Type: |
| Add. Headers: |
Parameters
Path parameters
| Name | Required | Type | Default Value | Description |
| operationId |
Operation ID of Output Creation operation |
Response
Success
| 204 No Content |
Operation cancellation requested |
Error
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
404 Not Found |
application/json |
Operation not found in Server |
