Installation Prerequisites
Users of Connect 1.1In order for users of PlanetPress Connect 1.1 to upgrade to any later version through the Update Manager it is necessary to install a later version (1.1.8 or later) of the Objectif Lune Update Client. If you do not have such a version installed already, the next time you run your Update Client it will show that there is an update available of itself to Version 1.1.8 (or later). Simply click on the download button in the dialog to install the new version of the Update Client. Note that it is no problem to run the update while the Client is open. It will automatically update itself. Once you have done this, PlanetPress Connect 1.7.1 will become available for download.
From PlanetPress Connect Version
1.2 onwards, the new version (1.1.8) of the Update Client is included by default
with all setups.
Users of Connect 1.0Users of this Connect version 1.0 cannot
upgrade directly to Version 1.7.1.
This is because Connect Version 1.0 is a 32 bit
version of Connect. If you are updating manually
you must first upgrade to Version 1.1 before installing 1.7.1. If you attempt go directly from Version 1.0 to Version 1.7.1 the installation
will fail. |
