User accounts and securityPermissions for PlanetPress Connect DesignerPlanetPress Connect Designer
does not require any special permissions to run besides a regular program.
It does not require administrative rights and only needs permission to
read/write in any folder where Templates If generating Print output, PlanetPress Connect Designer requires permission on the printer or printer queue to send files. Permissions for PlanetPress Connect ServerThe PlanetPress Connect Server module, used by the Automation module, requires some special permissions to run. These permissions are set during installation, in the Engine Configuration portion of the Installation Wizard, but it can also be configured later by modifying permissions for the service. To do this:
