boundaries
Returns a boundaries object encapsulating properties and methods allowing to define the boundaries of each document in the job.
This object is available when triggering document boundaries On script.
Properties
The following table lists the properties of the boundaries object.
Property Return Type
currentDelim A read-only 1-based index (number) of the current delimiter in the file. In other words, the Beginning Of File (BOF) delimiter equals 1. It indicates the position of the current delimiter relative to the last document boundary
Methods
The following table describes the functions of the boundaries object. They are available with all file types.
Method Description Script type
find() Finds the first occurrence of a string starting from the current position.
Boundaries
Preprocessor, Extract, Condition, Repeat, Action, and Postprocessor steps
get()
Retrieves an array of strings.
Boundaries
getVariable() Retrieves a value of a variable stored in the boundaries object.
Boundaries
set()
Sets a new record boundary. (See: Record boundaries.)
Boundaries
setVariable()
Sets a boundaries variable to the specified value, automatically creating the variable if it doesn't exist yet.
Boundaries
  • Last Topic Update: 27, June, 2017 06:10 AM
  • Last Published: 2019-05-23 : 3:18 PM
