record
The current record in the main data set.
Properties
Property Return Type
fields The field values that belong to this record. You can access a specific field value using either a numeric index or the field name,
index
The one-based index of this record, or zero if no data is available.
tables
The details table that belong to this record. You can access a specific table using a numeric index or the table name.
  • Last Topic Update: 27, June, 2017 06:10 AM
