Goto stepAlthough invisible, there is a cursor in the Data Viewer. In an extraction workflow, the cursor starts off at the top-left corner of each record in the source data. When the Goto step is used within a Repeat step, it moves the cursor in each loop of the Repeat step. In this case the new location has to be relative to the current position. The Goto step isn't used in XML extraction workflows The DataMapper moves through the file using Xpath, a path-like syntax to identify and navigate nodes in an XML document.
Adding a Goto stepTo add a Goto step:
Configuring a Goto stepFor information about how to configure the Goto step, see Goto step properties. |
