Preprocessor stepThe Preprocessor step allows the application to modify the incoming data prior to executing the rest of the extraction workflow through a number of preprocessors. It also lets you define properties, to be added to each record or to the data as a whole. A unique ID could be created to be added to each record in the output for integrity checks later on. A time stamp could be added to create reports. A tag could be added to process certain records differently. A preprocessor could remove certain records altogether. PropertiesTo add a property:
To set the value of a property you can use an Action step (see Action step). PreprocessorsThe Preprocessor step can contain any number of preprocessors. They will be run in sequence before the data is sent to the Data Mapping workflow. To add a preprocessor:
Configuring the Preprocessor stepFor an explanation of the settings for preprocessors, see: Preprocessor step properties. |
