Boolean
Booleans are a simple true/false data type often used in conditions and comparisons.
Defining Boolean values
  • Preprocessor:
    • In the Step properties pane, under Properties, add or select a field.
    • Specify the Type as Boolean and set a default value of either either true or false, followed by a semicolon.
  • Extraction:
    • In the Data Model, select a field.
    • On the Step properties pane, under Field Definition set the Type to Boolean.
    The field value must be true or false.
  • JavaScript Expression: Set the desired value to either true or false. Example: record.fields["isCanadian"] = true;
The value must be all in lowercase: true, false. Any variation in case (True, TRUE) will not work.
Boolean expressions
Boolean values can also be set using an expression of which the result is true or false. This is done using operators and comparisons.
Example: record.fields["isCanadian"] = (extract("Country") == "CA");
For more information on JavaScript comparison and logical operators, please see w3schools.com or developer.mozilla.org.
  • Last Topic Update: 27, June, 2017 06:10 AM
  • Last Published: 2019-05-23 : 3:18 PM
