Box Formatting dialog
The Text Formatting dialog is accessible by clicking inside a positioned
box in the template and then selecting Format > Box in the
menu.
When no unit is added to a geometry value, such as the width, height, top or margin, the default unit will be added to the value; see Print Preferences.
Box Tab
- General group:
- Width: Set the width
of the box in measure or percentage. When no unit is entered, the default unit will be added to the value (see Print Preferences). Equivalent to the CSS
width
property. - Height: Set the height
height
property. - Angle: Set the rotation
angle of the box in clockwise degrees. Equivalent to the CSS
transform:rotate property. - Corner radius: Set
the radius of rounded border corners in measure or percentage.
border-radius property. - Display: Use the drop-down
or type in the value for how to display the box. Equivalent to
the CSS
display property. - Overflow: Use the drop-down
or type in the value for how to handle overflow (text that does
not fit in the current size of the box). Equivalent to the
overflow
property.
- Text wrap group:
- Float: Use the drop-down
or type in the value for how to float the box, if the box is not
in an absolute position. Equivalent to the CSS
float property. - Clear: Use the drop-down
or type in the value for clearing pre-existing alignments. Equivalent
to the CSS
clear property.
- Positioning:
- Position: Use the drop-down
or type in the value for the type of positioning for the box.
position property. - Top: Set the vertical
offset between this box and its parent's top position. Equivalent
to the CSS
top property. - Left: Set the horizontal
offset between this box and its parent's left position. Equivalent
to the CSS
left property. - Bottom: Set the vertical
offset between this box and its parent's bottom position. Equivalent
to the CSS
bottom property. - Right: Set the horizontal
to the CSS
right property. - Z-index: Set the z-index
of the box. The z-index defines in which order elements appear. Equivalent
to the CSS
z-index property.
Background Tab
- General group:
- Color: Specify the
color of the box background. The color value must be a valid
HTML Color Name, or a valid HTML Hex Color.
background-color property.
- Background image group:
- Source: click the Select Image button to select an image via the Select Image dialog. Equivalent to the CSS
background property.
- Size: select
auto, cover or contain (for an explanation see http://www.w3schools.com/cssref/css3_pr_background-size.asp), or type the width and height of the image in a measure (e.g. 80px 60px) or as a percentage of the box size (e.g. 50% 50%). Equivalent to the CSS background-size property.
- Position: select the position for the background-image. Equivalent to the CSS
background-position property.
Spacing Tab
- Padding group: Defines
padding (spacing inside the element) in measure or percentage:
- All sides: Check to
set all padding to use the Top value. Equivalent to the CSS
padding
property. - Top, Left, Bottom, Right:
Set padding for each side. Equivalent to the CSS
padding-left, padding-top, padding-right and padding-bottom properties.
- Margin group: Defines margins
(spacing outside the element) in measure or percentage:
set all margins to use the Top value. Equivalent to the CSS
margin property. - Top, Left, Bottom, Right:
Set the margin for each side. Equivalent to the CSS
margin-left, margin-top, margin-right and margin-bottom properties.
Border Tab
- Same for all sides: Defines
the border properties for all sides using the Top properties. Equivalent
to the CSS
border property.
Each group defines the following properties:
- Width: Specify the
thickness of the border. Equivalent to the CSS
border-widthproperty. - Style: Specify the
style of the border such as
solid, dashed
or dotted. Equivalent to the CSS border-style property. - Color: Specify the
color of the border. The color value must be a valid HTML Color Name, or a valid HTML Hex Color.
border-color property.
