File properties
The File Properties dialog shows the characteristics of the template, such as the file name, author, creation date and keywords. It is also possible to add custom properties; customer name, for example.
To open the File Properties dialog, select File > Properties.
When a template report is generated, the file properties are part of it (see Exporting a template report).
The properties are available in scripts via the template object; see the Script API: template.
Description tab
  • File (read-only): The name of the file.
  • Author: The name of the author.
  • Company: The company the author works for.
  • Description: Enter a description of the template.
  • Keywords: Enter one keyword or a list of keywords, separated by semicolons.
  • Created (read-only): The date on which the template was created.
  • Modified (read-only): The date on which the template was last modified.
  • Application (read-only): the name and version of the application in which the template was last modified. The Connect version history of a template will be saved in the template file and exposed in a template report (see Exporting a template report).
Custom tab
On this tab custom properties can be defined. Click the Add icon and enter a name for the property and a value.
Use the arrow icons to reorder the list of custom properties.
Custom property lists can be exported to, and imported from, a .CSV file, using the Import and Export buttons.
  • Last Topic Update: 26, June, 2017 04:06 AM
  • Last Published: 2019-05-23 : 3:20 PM
