Send COTG TestThe Send COTG Test dialog is used to send a document to the Capture OnTheGo application, without the need to go through the Output to Capture OnTheGo task in PlanetPress Workflow (see Workflow Help: Output to Capture OnTheGo). Note that to the contrary of the Send to Capture OnTheGo task in Workflow, when using the Send COTG Test dialog, the contents of the file will be sent to the Nu-Book server. The Send to Capture OnTheGo task only sends document meta data to the Nu-Book server. The contents of the file are transmitted (by Workflow) when requested by the COTG app. For more information about testing a COTG template, see this how-to: Testing a COTG template. The dialog is only available on templates containing a Web context.
It does not, however, verify whether any Capture OnTheGo form elements
have been added to the page.
The dialog contains the following options:
