Sheet Configuration dialogThe Sheet Configuration dialog defines how different Print context sections output on different Media (see Media) and using different Master Pages (see Master Pages). There are multiple groups, each defining the settings for pages grouped by their position within the section as it outputs: First, Middle, Last and Single sheets. The first option defines Duplex printing, which also enables or disable the Back side of each sheet. If Duplex is enabled, you can also check Tumble to duplex pages as in a calendar, and Facing pages to have the margins of the section switch alternately, so that pages are printed as if in a magazine or book. If the option Same for all positions is checked, the same Master Page and Media will be applied to every page in the Print section. Each group defines:
