Table Cell Formatting dialog
Cell Tab
- Width: Set the width
of the table in measure or percentage. Equivalent to the CSS
width
property.
- Height: Set the height
height
property.
- Vertical Align: Specify
how text is vertically aligned in the cell: top, middle, bottom or baseline. With the baseline value all the table data share the same baseline. Often this has the same effect as the bottom value. However, if the fonts are in different sizes, baseline looks better.
Type Tab
- General group:
- Font: Select the
font used to display text, equivalent to the CSS
font-family
property. - Size: Enter the size
in measure, named size or percentage, equivalent to the CSS
font-size
property. - Color: Select a named
font color as defined in the Colors
Editor, create a new color or enter a color manually for text
to be displayed. The color value must be a valid HTML Color Name, or a valid HTML Hex Color.
color property.
- Spacing group:
- Letter Spacing: Set
the space between characters in a text in measure or percentage.
letter-spacing property. - Word Spacing: Set the
space between each word in a text in measure or percentage.
word-spacing property. - Whitespace: Specify
how to handle white spaces inside of an element. Equivalent to
the CSS
white-space property. See CSS White-Space for details.
- Style group: Check any
option to apply the selected style to text within the element:
- Bold: Sets the
font-weight to 700. - Italic: Sets the
font-style to italic. - Underline: Sets the
text-decoration to underline. - Strikethrough: Sets the
text-decoration to line-through. - Subscript: Sets the
vertical-align to super. - Superscript: Sets the
vertical-align to sub. - Capitalize: Sets the
text-transform to capitalize. - Uppercase: Sets the
text-transformto uppercase. - Lowercase: Sets the
text-transformto lowercase. - Small-caps: Sets the
font-variant to small-caps.
Spacing Tab
- Padding group: Defines
padding (spacing inside the element) in measure or percentage:
- All sides: Check to
set all padding to use the Top value. Equivalent to the CSS
border
property. - Top, Left, Bottom, Right:
Set padding for each side. Equivalent to the CSS
padding-left, padding-top, padding-right and padding-bottom properties.
Border Tab
- Same for all sides: Defines
the border properties for all sides using the Top properties. Equivalent
to the
border property.
Each group defines the following properties:
- Width: Specify the
thickness of the border. Equivalent to the CSS
border-width property. - Style: Specify the
style of the border such as
solid, dashed
or dotted. Equivalent to the CSS border-style property. - Color: Specify the
color of the border. The color value must be a valid HTML
border-color property.
Background Tab
- General group:
color of the table cell background. The color value must be a valid
background-color property.
- Background image group:
- Source: click the Select Image button to select an image via the Select Image dialog. Equivalent to the CSS
background property.
- Size: select
auto, cover or contain (for an explanation see http://www.w3schools.com/cssref/css3_pr_background-size.asp), or type the width and height of the image in a measure (e.g. 80px 60px) or as a percentage of the parent element's size (e.g. 50% 50%). Equivalent to the CSS background-size property.
- Position: select the position for the background-image. Equivalent to the CSS
background-position property.
