Table Formatting dialog
The Table Formatting dialog defines how the table looks and reacts.
Table Tab
- General group:
- Width: Set the width
of the table in measure or percentage. Equivalent to the CSS
width
property. - Height: Set the height
height
property. - Angle: Set the rotation
angle of the table in clockwise degrees. Equivalent to the CSS
transform:rotate property. - Corner radius:
Set the radius of rounded border corners in measure or
border-radius property. - Display: Use the
drop-down or type in the value for how to display the table.
Equivalent to
the CSS
display property. - Overflow: Use the
drop-down or type in the value for how to handle overflow
(text that does not fit in the current size of the box). Equivalent to the CSS
overflow
property.
- Text wrap group:
- Float: Use the
drop-down or type in the value for how to float the table, if
the table is not in an absolute position. Equivalent to the CSS
float property. - Clear: Use the
drop-down or type in the value for clearing pre-existing alignments.
Equivalent
to the CSS
clear property.
- Positioning:
- Position: Use the
drop-down or type in the value for the type of positioning
for the table. Equivalent to the CSS
position property. - Top: Set the vertical
offset between this table and its parent's top position. Equivalent
to the CSS
top property. - Left: Set the horizontal
offset between this table and its parent's left position. Equivalent
to the CSS
left property. - Bottom: Set the
vertical offset between this table and its parent's bottom position.
bottom property. - Right: Set the
horizontal offset between this table and its parent's left position.
right property. - Z-index: Set the
z-index of the table. The z-index defines in which order elements appear. Equivalent
to the CSS
z-index property.
- Breaks group:
- Before: Specifies
how to handle page breaks before the table. Equivalent to
the CSS
page-break-before property. - Inside: Specifies
whether to accept page breaks within the table. Equivalent
to the CSS
page-break-inside property. - After: Specifies
how to handle page breaks after the table. Equivalent to
the CSS
page-break-after property. - Widows: Specifies
how to handle widows within the table (rows appearing alone
on the next page if the table does not fit on the current
one). Equivalent to the CSS
widows property. Widows
and orphans are ignored if the page-break-inside
property is set to avoid. - Orphans: Specifies
how to handle orphans within the tables (rows appearing alone
at the end of a page if the table does not fit on the current
orphans property.
Spacing Tab
- Padding group: Defines
padding (spacing inside the element) in measure or percentage:
- All sides: Check to
set all padding to use the Top value. Equivalent to the CSS
padding
property. - Top, Left, Bottom, Right:
Set padding for each side. Equivalent to the CSS
padding-left, padding-top, padding-right and padding-bottom properties.
- Margin group: Defines
margins (spacing outside the element) in measure or percentage:
set all margins to use the Top value. Equivalent to the CSS
margin property. - Top, Left, Bottom, Right:
Set the margin for each side. Equivalent to the CSS
margin-left, margin-top, margin-right and margin-bottom properties.
Border Tab
- Same for all sides:
Defines
the border properties for all sides using the Top properties. Equivalent
to the CSS
border property.
Each group defines the following properties:
- Width: Specify the
thickness of the border. Equivalent to the CSS
border-widthproperty. - Style: Specify the
style of the border such as
solid, dashed
or dotted. Equivalent to the CSS border-style property. - Color: Specify the
color of the border. The color value must be a valid HTML Color Name, or a valid HTML Hex Color.
border-color property.
Background Tab
- General group:
color of the table background. The color value must be a valid
HTML
background-color property.
- Background image group:
- Source: click the Select Image button to select an image via the Select Image dialog. Equivalent to the CSS
background property.
- Size: select
auto, cover or contain (for an explanation see http://www.w3schools.com/cssref/css3_pr_background-size.asp), or type the width and height of the image in a measure (e.g. 80px 60px) or as a percentage of the parent element's size (e.g. 50% 50%). Equivalent to the CSS background-size property.
- Position: select the position for the background-image. Equivalent to the CSS
background-position property.
